12 years agoAVGT development board PCIe and SFP pin assignment
can i use pcie and sfp on the AVGT development board's FPGA1 at the same time?
11 years agoTo lihaiquan,
I'l having a similar problem: after assigning some output pins I get the error: Error (12857): HIP reset pin "i_pcie_perst" is locked to "PIN_BD35", which is not legal. The pins that I assigned are output signals which goes to the transceiver, and are placed in: set_location_assignment PIN_W41 -to o_serial_data_GBT[0] set_location_assignment PIN_U41 -to o_serial_data_GBT[1] set_location_assignment PIN_R41 -to o_serial_data_GBT[2] set_location_assignment PIN_L41 -to o_serial_data_GBT[3] set_location_assignment PIN_N41 -to o_serial_data_GBT[4] set_location_assignment PIN_J41 -to o_serial_data_GBT[5] As you can see they are quite far from PIN_DB35, which is the one giving problems. The funny thing is that if I don't assign any pin to o_serial_data_GBT then the error goes away. Did you still remember what you had to do to solve the problem? Thanks in advance. PD: somehow related to this: http://xkcd.com/979/
