srinivasan
5 years agoAvalon st single clock fifo
Hi, I am using Avalon st single clock FIFO...In that how to give CSR data and address. Otherwise can anyone share the reference design using CSR in Avalon FIFO...
Nurina
5 years agoHi Srinivasan,
Did the above reply address your problem? Do you have more questions?
Nurina
PS: If you find any comment from the community or Intel Support to be helpful, feel free to give Kudos.
- srinivasan5 years ago
Thanks for your reply,
Already that pdf only I am following,but I want about CSR address means which register value need to assign in that signals..
I don't know what input need to give for that IP..
Can you please share the testbench for that IP or any design or simulation result... - srinivasan5 years ago
can u please share the CSR registers configuration document details....
