aamlb
5 years agoArria10SoC Development kit: Failing to burn the on board QSPI flash
I prepared a binary stream for burning to the QSPI flash: 128MB (MT25QU01GBBA8E12-0SIT), which installed on J11.
I followed the instructions on https://community.intel.com/t5/FPGA-Wiki/G...
YuanLi_S_Intel
5 years agoHi,
The ini file is meant to have micron flash memory to be selectable. Also, you chip select is pointing to 0x1? that means 2nd device? Can you confirm?
The configuration scheme i meant, you may take a look at user guide below:
You need to set to AS x4.
Also, would like to check, when you program the JIC normally without the setup, is the programming successful? Also, is the ID shown correct?
Thank You.
Bruce
