aamlb
5 years agoArria10SoC Development kit: Failing to burn the on board QSPI flash
I prepared a binary stream for burning to the QSPI flash: 128MB (MT25QU01GBBA8E12-0SIT), which installed on J11.
I followed the instructions on https://community.intel.com/t5/FPGA-Wiki/G...
YuanLi_S_Intel
5 years agoHI,
Sorry for being late as i have been checking with internal team. The possible issue for causing this is due to IP setting problem and Config Device Selection problem.
Just would like to understand on this, what are the device you selected?
https://fpgacloud.intel.com/devstore/platform/18.1std.1/Standard/generic-serial-flash-interface-and-nios-ii-booting/ (Page 15 in PDF)
As you are using 1GB micron flash devices, the device density should be 1024 Mb instead of 128 Mb. Can you please try?
Thank You
