AHano
7 years agoArria10 GX Development kit: Problems with finding Arria10 device in the JTAG Chain
Hello, I pressed S7 bottun to reset the board bay mistake, after reseting the Max5 device on the Arria GX board, the Led D16 became red. since then, the board is behaving strangely. the Arria10 ...
AHano
7 years agoDear Mr. Nooriani,
Thank you for your reply.
Actually, all the settings were correctly made; all switches are correctly set. The problem is that the Arria 10 chip is on the chain for only 10-20 seconds and then disapear from the chain. which hints at some issues with stability of the power supply of the Arria 10. Or at least may be, that one of the power pins is not delivering the right voltage-level.
Best wishes
