AHano
7 years agoArria10 GX Development kit: Problems with finding Arria10 device in the JTAG Chain
Hello, I pressed S7 bottun to reset the board bay mistake, after reseting the Max5 device on the Arria GX board, the Led D16 became red. since then, the board is behaving strangely. the Arria10 ...
AHano
7 years agoDear Nooriani,
Thank you for your reply. Actually, all jumpers are set correctly. I figured out using the Linear Technology DC1613A Software, that the power regulator on board is not working correctly. U0.5 is dead after 10-20 seconds. This causes this problem. Do you suggest any technical support contacts so that we can fix it.
