13 years agoArria V GX Starter Kit
Is Arria V GX Starter Kit (http://www.altera.com/products/devkits/altera/kit-arria-v-starter.html) really available?
I tried to contact Altera sales but they said they don't have this board in their database? The same reply from distributor. Also, does anybody know about dev board(s) with Arria V GZ?13 Replies
Hi all,
I am trying to evaluate the Arria V GX whether it will meet the speed requirements for my design, supposing to run on the Arria V GX Starter Kit. I am using Altera Web edition but this one doesn't seem to support Arria V GX. In the web documentation of the full edition of Quartus I don't see the Arria V GX neither (it has Arria V and Arria V GZ but not GX). The license price is too high just for trying and concluding it might not suit my design. How did you guys compile your designs? BR, Wim - Altera_Forum
Sols, is there a method documented for converting a design using one Arria chip -> the one on the Starter Kit ? I believe you indicate that is what you did.
I can chhange the part number but alos need to map the Starter Kit pin allocation as well. - Altera_Forum
I need a Nios II running a some C code and movind data to and from the host ( rc ) memory.
I sas through the class on the Arria V Hard PCIe IP today and it seems tha tbetween the PCIe IP and the NIOS II there is quite some logic to handle PCIe protocol. I was thinking that logic was in the Hard PCIe IP. I don't need the streaming performance more the processing ability of the NOPS II to work through a set of descriptors in the host memory. IN the DMA examples , I believe the logic I refer to is in the APP level. For the memory mapped Avalon PCIe IP, is there a mega function that handles the PCIe traffice at the MM Avalon level where data reads and writes to memory are presented as normal bus transactions ? Thanks, Bob.
