12 years agoArria V GX Starter Kit - Quartus II DKE? One year license?
Hi guys, I want to start using higher density FPGAs for academic research. Currently I am looking at the Arria V GX Starter Kit. Especially since it is able half the price of the Kintex-7 evalu...
12 years ago --- Quote Start --- I would advise ton contact your FAE or local distributor if you have problems with your license, they should be able to help you. Are you sure the 13.1 version you downloaded was a subscription edition, not the web edition? IIRC when the license expires, Quartus opens a window at startup with different choices. One of them is to continue using the expired license. --- Quote End --- Hi, Thank you for your reply. There's no such options of "continue to use the expired license". I've checked and It's full edition. It worked fine with my 1-year license granted when I purchased the development kit. Now it just stops working, contacting the support but no news so far. https://www.alteraforum.com/forum/attachment.php?attachmentid=8976 Best regards, Jeff
