Arria V - Q18- Time quest. We have some kind of problems using "set_output_delay" command. We are using Q18 and Q18.1.
Hi JOter,
In the design, the output delay is set to only OUTPUT[0]. May I know what are the both signals mentioned? What is the signals that are not ok as there is no violation in the design?
- JOter7 years ago
Thank you for your answer. I didn't see it until now, because a was waiting it in the support panel instead of "Comunity" panel.
In reference to your question the signal are: RAM_CLK (CLK) and OUTPUT 0 (counter)
We tested both signal in one scope, and we didn't notice any change between them changing the OUTPUT_DELAY constraints.
Remenber we checked it also using a C III, and in this case we got the spected signal.
We used the next constrains commands:
set_output_delay -clock vt_RAM_CLK -max [expr $RAM_tsetup + $RAM_BDb_max - $RAM_CLK_DLY_MIN] [get_ports {OUTPUT[0]}]
set_output_delay -clock vt_RAM_CLK -min [expr -$RAM_thold + $RAM_BDb_min - $RAM_CLK_DLY_MAX] [get_ports {OUTPUT[0]}]
And
set_output_delay -clock RAM_CLK -max [expr $RAM_tsetup + $RAM_BDb_max - $RAM_CLK_DLY_MIN] [get_ports {OUTPUT[0]}]
set_output_delay -clock RAM_CLK -min [expr -$RAM_thold + $RAM_BDb_min - $RAM_CLK_DLY_MAX] [get_ports {OUTPUT[0]}]
Best regards
