Patricia
6 years agoArria 10 SoC emif preset library family device does not match family device of the Dev Kit
I am trying to use the external memory interface IP and when I choose a device in the presets on the IP Parameter Editor (for arria 10 SoC) the arria 10 device family is not the same as the one...
yoichiK_altera
Contributor
6 years agoHi
Would you elaborate more about IP parameter you referred to ?
attaching picture is what you refereed to IP parameter ?
- Patricia6 years ago
That's what I was referring to: the device family from the preset is not the same as the SoC board I have...
But I programed the device i have with the example and it seems to work fine.
Patricia
- sstrell6 years ago
If you want to guarantee you're using the correct implementation and parameterization for your board, instead of choosing the preset from the parameter editor, use the example memory design that is included as part of the software download for the board.
#iwork4intel
- yoichiK_altera6 years ago
Contributor
Hi Patricia
You are choosing the right one because there is only one kind of Arria10 SOC development kit.
