Arria 10 SoC DevKit: Can I drive DB-9 RS-232 port from HPS UART0 ?
- 7 years ago
I now have the HPS UART0 routed through the FPGA OK to the DB9 RS-232 port.
The UART_RS232 soft IP is not required in the FPGA.
My problem here was caused by the RS-232 PHY on the dev board operating in an auto-shutdown mode that meant that the external tx/rx loopback test I was attempting would never wake the PHY.
Paul
Paul
How did you do this? What is FPGA OK? I have a design in my FPGA and I'm not using the HPS at all, and I want to use UART to send data to the design in the FPGA. Is this what you also did, and How?
I hope you can help me understand what's going on,
Gurol
- PHJ6 years ago
Hi Gurol -
We configured the pinmux in the HPS to route UART0 via the FPGA:
/* UART0 routed via FPGA */
alt_write_word(ALT_PINMUX_FPGA_UART0_USEFPGA_ADDR, ALT_PINMUX_FPGA_UART0_USEFPGA_SEL_SET(1));
We configured the FPGA to route the HPS UART0 signals to the appropriate input/output pins of the A10 - we only used tx/rx as we were not using flow control.
Paul
