PHJ
8 years agoArria 10 SoC DevKit: Can I drive DB-9 RS-232 port from HPS UART0 ?
The user guide indicates that this is available after FPGA configuration. What needs to be configured for this to work ? Does the GSRD support this ?
- 7 years ago
I now have the HPS UART0 routed through the FPGA OK to the DB9 RS-232 port.
The UART_RS232 soft IP is not required in the FPGA.
My problem here was caused by the RS-232 PHY on the dev board operating in an auto-shutdown mode that meant that the external tx/rx loopback test I was attempting would never wake the PHY.
Paul
Ahmed_H_Intel1
7 years agoHi,
I will check what configuration you need and will let you know shortly.
