arria 10 interoperability reference design is not work..!
Dear all,
Has this design worked on this device (10AX115S2F45ISG, production device)? I tried with all versions of quartus 15.1 to 19.1 pro but it does not work. I have tried with the dacs ad9144 and 9154 too.
On 15.1 no sof is created because quartus says that the device is "advanced". On 16.1 the sof is created but I can't download the .sof on board because of the opencore license management. I download the .sof but jtag loses connection immediately.On 17 and forwards I can download the design but no data comes out of the DAC.
I observed when I run the software that the SPI seems to work and all plls are locked but it says that TX calibration has failed and then when it reads the jesd204 configurations from the dac, all the parameters are zero.
I followed the steps from this guide https://www.intel.com/content/dam/altera-www/global/en_US/uploads/3/3c/A10_jesd204b_ad9144_ad9625_ug.pdf
Any ideas?
Thanks in advance.
Hi all,
Did anyone managed to run the 'Arria 10 JESD204B AD9144-AD9625 Interoperability Reference Design' on the '10AX115S2F45ISG' device?
Thank you
