KSchi
6 years agoArria 10 HPS: Platform Designer Error: Unsupported Device under Linux (Windows works)
I have a Quartus project for Arria 10 10AS016E4F29E3SG which contains a Platform Designer project with HPS and EMIF for HPS (no other IPs). When running the Quartus software on Linux I get an error f...
KennyT_altera
6 years agoI try to run your design in Q19.3 redhat 7.5. I did not get any failure. I had try to generate the qsys and also run the analysis. Both without any error.
What linux you were using? Also, can you look in assignment -> device. Check whether this device was installed in linux?
