User1580871742356367
6 years agoArria 10 HPS DDR4 calibration fail and no emif_usr_clk
Story: HPS DDR4 calibration failed (discrete, 32bit). No emif_usr_clk by putting signal tap PLL locked both local_cal_success and local_cal_fail are LOW Questions: Why there was no emif_us...
sstrell
6 years agoWhat leads to you believing there is no emif_usr_clk? Do you not see it coming from the IP in Platform Designer?
And the first stage bootloader is what runs to initialize and calibrate the external memory, so this is before uboot for Arria 10.
#iwork4intel
- User15808717423563676 years ago
Thank you very much for the reply.
emif_usr_clk is used as Signal Tap clock and Signal Tap was triggering and waiting for the clock.
