Arria 10 GX FPGA Dev Kit OpenCL and PCIe drivers/runtime stopped working
May I know the information as below:
1. Did aocl install pass?
2. Did jtagconfig pass?
3. Did aocl program pass?
4. Does the PC reboot when program the FPGA?
5. What is the LCD display on the devices?
Hi Mylee
Here are my answers to your question:
1) I think so, here is the output:
root@hpvmfpga:[/home/aejjeh]: aocl install
Do you want to setup the FCD at directory /opt/Intel/OpenCL/Boards [y/n] y
aocl install: Adding the board package /opt/intelFPGA_pro/19.1/hld/board/a10_ref to the list of installed packages
aocl install: Setting up the FPGA Client Driver (FCD) to the system.
Install the FCD file to /opt/Intel/OpenCL/Boards
Installing the board package driver to the system.
aocl install: Running install from /opt/intelFPGA_pro/19.1/hld/board/a10_ref/linux64/libexec
Looking for kernel source files in /lib/modules/4.15.0-66-generic/build
Using kernel source files from /lib/modules/4.15.0-66-generic/build
Building driver for BSP with name a10_ref
make: Entering directory '/usr/src/linux-headers-4.15.0-66-generic'
CC [M] /tmp/opencl_driver_6kHrDJ/aclpci_queue.o
/tmp/opencl_driver_6kHrDJ/aclpci_queue.c: In function ‘queue_push’:
/tmp/opencl_driver_6kHrDJ/aclpci_queue.c:133:3: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
void* dest = queue_addr(q, loc);
CC [M] /tmp/opencl_driver_6kHrDJ/aclpci.o
CC [M] /tmp/opencl_driver_6kHrDJ/aclpci_fileio.o
CC [M] /tmp/opencl_driver_6kHrDJ/aclpci_dma.o
CC [M] /tmp/opencl_driver_6kHrDJ/aclpci_pr.o
CC [M] /tmp/opencl_driver_6kHrDJ/aclpci_cmd.o
/tmp/opencl_driver_6kHrDJ/aclpci_cmd.c: In function ‘aclpci_exec_cmd’:
/tmp/opencl_driver_6kHrDJ/aclpci_cmd.c:176:5: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
size_t bytes_copy = strnlen(ACL_BOARD_PKG_NAME, BUF_SIZE) + strnlen(ACL_DRIVER_VERSION, BUF_SIZE) + 2; // 1 for '.', 1 for '\0'
LD [M] /tmp/opencl_driver_6kHrDJ/aclpci_a10_ref_drv.o
Building modules, stage 2.
MODPOST 1 modules
CC /tmp/opencl_driver_6kHrDJ/aclpci_a10_ref_drv.mod.o
LD [M] /tmp/opencl_driver_6kHrDJ/aclpci_a10_ref_drv.ko
make: Leaving directory '/usr/src/linux-headers-4.15.0-66-generic'2) Yes, jtagconfig passes
root@hpvmfpga:[/home/aejjeh]: jtagconfig
1) USB-BlasterII [2-1.7]
02E660DD 10AX115H1(.|E2|ES)/10AX115H2/..
020A40DD 5M(1270ZF324|2210Z)/EPM22103) I cannot run aocl program because aocl does not detect the device to start with
4) Not sure what you mean here, I reboot the machine manually when I am trying to initialize the board. I have a script that I use to initialize the board based on the AN 807 Intel document: https://www.intel.com/content/www/us/en/programmable/documentation/tgy1490191698959.html#wmh1490212984610
Basically, I set the jtag speed to 6M, then I run the following two commands:
quartus_pgm -c 1 -m JTAG -o "p;max5_150.pof@2"
quartus_pgm -c 1 -m JTAG -o "p;top.sof"After that I do a soft reboot. When the reboot is done, I used to run aocl install and then the board would work.
5) The board is inside the PC chassis. I cannot see the LCD display while the board is connected to PCIe.
