8 years agoArria 10 GX FPGA dev kit examples: JTAG ID code issue
I'm attempting to load the current example files for the Arria 10 GX FPGA dev kit and it is coming up with: Error (209015): Can't configure device. Expected JTAG ID code 0x02E860DD for device 1...
8 years agoHi,
Are you using USB blaster II. If yes can you reduce the TCK clock frequency to 16 MHz or 6 MHz and check once.jtagconfig --setparam 1 JtagClock 6M https://www.altera.com/en_us/pdfs/literature/ug/ug_usb_blstr_ii_cable.pdf Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
