9 years agoArria 10 GX DevKit Windows Installer?
I'm missing something. I've downloaded the software package (arria10GX_10ax115sf45_fpga_v15.1.2p2.zip) and unzipped it into my altera installation directory. The user guide and website refer to...
9 years ago --- Quote Start --- For Board test system, it will look for the default Quartus installation and version in your PC. You need to have Quartus 15.1.2 installed in your PC (older/newer versions may not work) --- Quote End --- Thank you for taking the time to reply. I appreciate it. I filed a service request and they said pretty much the same thing, but there's no change. BoardTestSystem.exe still will not come up. Nothing happens when I open it. Board test files have been extracted into my c:/altera/15.1 directory I can get to the update portal and used it to reset the board to factory. The procedure for doing this is very different if you compare the Quick Start Guide to the User Guide. I followed the Quick Start Guide instructions and uploaded a new file. After uploading and hitting the two config buttons, all the LEDs just turned red. The User Guide documentation doesn't seem very accurate either. I've verified the dip switch settings, but I don't have a lot of confidence in the Altera docs/diagrams at the moment. Quartus 15.1 is running. SignalTap shows the two correct devices in the jtag chain. The PC I'm using is running Win7sp1. (i7 w/ 16GB ). Not sure what to try next.
