8 years agoArria 10 GX Dev Kit DMA over PCIe
Hello everyone. I am trying to acquaint myself with the functionality of DMA over PCIe on the Arria 10GX Development Kit. I downloaded the reference design from the Design Store here (https://cloud.a...
8 years ago --- Quote Start --- The board doesn't show up in lspci. I found this other link on the forums about a similar issue, but it doesn't seem to have a conclusive result: https://www.alteraforum.com/forum/showthread.php?t=56902 --- Quote End --- Hi, If you are using a different quartus version rather than standard edition 16.0, make sure that you regenerate the qsys file of the PCIe HIP and successfully recompile the whole design. Also, make sure that you don't use an extension PCI cable to connect the FPGA to the motherboard. Hope this helps.
