epissadakis
1 year agoArria 10 GX , Cyclone 10 GX transceiver phy compatibility
Hello , I am trying to establish communication between a cyclone 10 GX device and an Arria 10 GX device using the transceiver phy ip core but i have the following issue. The data from the Arria ...
CheepinC_altera
1 year agoHi,
Regarding the status signals, feel free to share the following A10 RX signals for further review:
rx_cal_busy
rx_is_lockedtoref
rx_is_lockedtodata
These will help in assessing the RX calibration and lock status.
As for rx_std_signaldetect, it typically works in conjunction with the signal detect threshold set in the QSF file. Just to confirm, do you observe this signal de-asserting when the SMA cable is disconnected?
Thank you.
epissadakis
1 year agoWhen i connect the device rx_is_lockedtodata is always high , when i disconnect it this signal asserts and de-asserts.
