epissadakis
1 year agoArria 10 GX , Cyclone 10 GX transceiver phy compatibility
Hello , I am trying to establish communication between a cyclone 10 GX device and an Arria 10 GX device using the transceiver phy ip core but i have the following issue. The data from the Arria ...
CheepinC_altera
1 year agoHi,
Regarding your inquiry on the XCVR electrical specs, you may refer to the following tables in the Intel® Cyclone® 10 GX Device Datasheet and Intel® Arria® 10 Device Datasheet:
1. Receiver Specifications
2. Transmitter Specifications
These tables include key parameters such as VOCM, VICM, VID, and others.
Please feel free to reach out if you have any questions or need further clarification.
Thank you!
epissadakis
1 year agoHello,
I have already read these datasheets but i could not find any specific reference regarding VOCM, VICM, VID related to the I/O standard "High speed differential I/O" .
Is it related to any SSTL-12 CLASS I , SSTL-18 CLASS I , or any similar I/0 e.g from the table 15 in the Cyclone® 10 GX Device Datasheet?
Manolis
