Arria 10 GX , Cyclone 10 GX transceiver phy compatibility
Hello ,
I am trying to establish communication between a cyclone 10 GX device and an Arria 10 GX device using the transceiver phy ip core but i have the following issue.
The data from the Arria 10 to Cyclone 10 device seems to be correct , but in the opposite path (Cyclone to Arria ) i do not retrieve valid data.
Are these devices compatible ? Is there any electrical incompatibility in the transceiver phy between these devices ?
*The cable i use is SMA without any external buffers
Manolis
- CheepinC_altera
Hi Manolis,
As I understand it, you're observing some issues in the datapath between the C10 transmitter and the A10 receiver. Regarding your specific question on the electrical compatibility between C10 TX and A10 RX, I’ve reviewed their datasheets and, based on the specifications, there should be no issue interfacing the two devices electrically.
To help facilitate further debugging, I’d like to check on a few points:
1. Status Signals:
Could you please share the status signals from both the C10 TX and the A10 RX? This information would help us assess the current state of the link and determine the next steps in debugging.
2. Signal Integrity Check:
Have you had a chance to probe the C10 TX SMA output with an oscilloscope to inspect the eye diagram? This would help rule out any signal integrity issues at the transmitter side.
3. Loopback Test:
You might also consider performing an SMA loopback from the C10 TX to the C10 RX. This can help verify whether the C10 TX is functioning correctly in isolation.
Please let me know if you have any concerns. Looking forward to your update.
- epissadakis
Could you please attach the electrical specification of the transceiver phy , because i did not find anything that exactly refers to high speed differential I/O standard neither for Arria nor Cyclone device.
Regarding the status signals , the rx_signaldetect is always high which means that electrically is connected a remote device. Is it correct?
The loop back between the cyclone RX-TX is working as expected.
Manolis
- CheepinC_altera
Regarding your inquiry on the XCVR electrical specs, you may refer to the following tables in the Intel® Cyclone® 10 GX Device Datasheet and Intel® Arria® 10 Device Datasheet:
1. Receiver Specifications
2. Transmitter Specifications
These tables include key parameters such as VOCM, VICM, VID, and others.
Please feel free to reach out if you have any questions or need further clarification.
Thank you!
- epissadakis
I have already read these datasheets but i could not find any specific reference regarding VOCM, VICM, VID related to the I/O standard "High speed differential I/O" .
Is it related to any SSTL-12 CLASS I , SSTL-18 CLASS I , or any similar I/0 e.g from the table 15 in the Cyclone® 10 GX Device Datasheet?
Manolis
- CheepinC_altera
Regarding the status signals, feel free to share the following A10 RX signals for further review:
rx_cal_busy
rx_is_lockedtoref
rx_is_lockedtodata
These will help in assessing the RX calibration and lock status.
As for rx_std_signaldetect, it typically works in conjunction with the signal detect threshold set in the QSF file. Just to confirm, do you observe this signal de-asserting when the SMA cable is disconnected?
Thank you.
- epissadakis
When i connect the device rx_is_lockedtodata is always high , when i disconnect it this signal asserts and de-asserts.
- CheepinC_altera
Regarding the specification, the following is an example for the RX specifications for VID and VICM:
- CheepinC_altera
Thanks for your update regarding the A10 rx_is_lockedtodata = 1 when the SMA is connected. Based on this, I presume that rx_cal_busy = 0 and rx_is_lockedtoref may be toggling, which suggests that the A10 RX CDR has reached the LTD (Lock to Data) state.
To assist further, I’d like to check on a few points:
Debug Suggestions:
1. Fixed Pattern Transmission
Have you had a chance to transmit a fixed pattern (e.g., 0xBC) from the C10 TX to the A10 RX? Using a fixed pattern can simplify debugging and data monitoring, and is generally less susceptible to noise compared to PRBS patterns.
2. Eye Diagram Inspection
Would you be able to use an oscilloscope to inspect the eye diagram as close as possible to the A10 RX package balls? This might help identify any signal anomalies.
Additional Checks (for completeness only, I believe you have checked these):
1. Are the reconfig_clk, refclk, and CLKUSR clocks sourced directly from free-running oscillators?
2. Please double-check the clock frequencies and signal integrity for any irregularities.
3. Also, verify the power supplies—especially those related to the transceiver—for any potential issues.
Let me know if you have any concerns or need further assistance. Thank you!
Chee Pin
- CheepinC_altera
Just following up on my previous message—please feel free to reach out if you have any questions or concerns.
Also, I noticed that the snapshot I included earlier regarding the RX specifications might not have displayed correctly. For your reference, you can find the receiver specifications in the A10 device datasheet under Table 33: Receiver Specifications.
Let me know if you need any further clarification.
Chee Pin
- epissadakis
Thanks for the information. I will take a look at this and if i have any question I will come back.
Manolis
- CheepinC_altera
Hi Manolis
Thanks for your update.
- CheepinC_altera
Thank you for your participation in this thread.
As we haven’t received a response to our previous message, we’ll now transition this case to community support. If you have a new question or need further assistance from Intel experts, please feel free to open a new thread.
Otherwise, community members are welcome to continue supporting you here.
Thank you again, and we appreciate your engagement.
