ramsoffer_123
2 years agoArria 10 EMIF example design error
hi everyone, im using Arria 10 GX development kit. im trying to learn EMIF example design. im using ARRIA 10 GX development kit with DDR4 HILO preset. memory parameters: memory clock freq:1066.6...
AdzimZM_Altera
2 years agoHi Ram,
The example design should be able to support other clocks value.
If you are not sure about that, you can configure the EMIF IP setting with other clock value and run a compilation.
If the timing report shows that there is no issue with DDR timing, then the design should be okay.
I can suggest to run a DDR4 test with BTS application.
Also can you use latest Quartus release to run the test?
Adzim
