9 years agoArria 10 Development Kit Board to Board Connection
Are there FMC cables available to connect 2 Arria 10 Development boards together? I've checked with a couple of vendors and I'm not sure what is needed. Tx pairs from one board need to connect with...
9 years ago --- Quote Start --- Are there FMC cables available to connect 2 Arria 10 Development boards together? I've checked with a couple of vendors and I'm not sure what is needed. Tx pairs from one board need to connect with Rx pairs on the other and vice versa. We had a similar cables for use with the HSMC connectors on previous generation development boards. Thanks, Matt --- Quote End --- Hi Matt, This is how we connect two TR5 with the FMC to FMC cable, but we currently don’t supply this cable. https://www.alteraforum.com/forum/attachment.php?attachmentid=12843 We purchased the FMC cable (HDR-153514-XX) from Samtec directly, and I think you might want to check if they can provide this unit to you as well. However, since we don’t know which specific Arria 10 Dev. Board you intend to connected with, I’m not quite sure if every mother board can use the same type of the cable as we used. Let me know if you have any question. Thanks. Regards, Mavis
