9 years agoArria 10 Development Kit Board to Board Connection
Are there FMC cables available to connect 2 Arria 10 Development boards together? I've checked with a couple of vendors and I'm not sure what is needed. Tx pairs from one board need to connect with...
9 years ago --- Quote Start --- I believe the first three cables listed here do what you want: http://www.hitechglobal.com/fmcmodules/fmc_cable.htm --- Quote End --- Thank you for the link. However, I think the problem is that the connectors have to be on the opposite side. I think mechanically, the only way to connect two boards together is to stack the two boards and have a cable similar to the one pictured in that link. However, the first 3 (board to board) have the connectors on the same side. I believe the heat sink on the Arria 10 board would prevent using cables with connectors on the same side. I have a request into HiTech Global but have not heard a response as of yet. Thanks, Matt
