shager
6 years agoArria 10 CvP
I am currently trying to implement Configuration via Protocol (CvP) for our design on an Arria 10 PCI board. I managed to make CvP work when I do it once after a machine cold start. However, ...
- 6 years ago
The white paper you mention is only applicable for V series device. CvP udpate is not supported in Arria 10. So you will need to you partial reconfiguration if you would like to update the core image.
JohnT_Altera
6 years agoHi,
May I know when you mention you are performing CvP the second time, are you programming the same core image used during cold boot? The reason is that Arria 10 does not support CvP Update. In order to update the design, you are recommended to use Partial Reconfiguration features.
Please refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_a10_cvp_prop.pdf.
