Arria® 10 GX FPGA Development Kit, Factory Reset
MSEL setting is important in determining which programming file to load. Your existing MSEL setting is meant for passive serial / fast passive parallel configuration scheme.
Can you try to change your MSEL to OFF OFF ON? Then try to load the JIC file again?
It appears something is wrong with the board, the computer now can't even detect the hardware. I tried different MSEL settings. I tried on board and off board usb blasters. I am not sure what is wrong.
The onboard USB Blaster is not detected, and using an offboard USB Blaster(J17) the autoscan fails.
I tried the other Jtag port for the Max2 (J23) and it detects the Max2.
Before I was able to program .sof and now nothing. I tried switching pins on SW4 to enable and disable JTAG, and both settings don't work.
I was wearing anti static wrist band.
