Arria® 10 GX FPGA Development Kit, Factory Reset
MSEL setting is important in determining which programming file to load. Your existing MSEL setting is meant for passive serial / fast passive parallel configuration scheme.
Can you try to change your MSEL to OFF OFF ON? Then try to load the JIC file again?
- jdun5 years ago
It appears something is wrong with the board, the computer now can't even detect the hardware. I tried different MSEL settings. I tried on board and off board usb blasters. I am not sure what is wrong.
The onboard USB Blaster is not detected, and using an offboard USB Blaster(J17) the autoscan fails.
I tried the other Jtag port for the Max2 (J23) and it detects the Max2.
Before I was able to program .sof and now nothing. I tried switching pins on SW4 to enable and disable JTAG, and both settings don't work.
I was wearing anti static wrist band.
