Are quartus_sta not working for MAX 10
Thanks, I was able to launch it.. can attached over your design.qar as well? Otherwise I will have to create it.
I have made an example project
- KennyT_altera7 years ago
This seems to be a bug, however, Quartus std version are only in maintenance mode. There will be no fix on the bug because in pro edition there are no longer soft LVDS.
What you can do is write the sdc file on your own. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_altlvds.pdf page 45.
We will file a kdb to let other customer know on this.
- JChri17 years ago
You are aware that MAX 10 is not supported by pro edition?
So what you are stating is that Intel is going to discontinue or stop supporting MAX series together with Stratix (IV, V), Arria (II, V), Cyclone(IV, V, 10LP)?
The only devices supported by pro edition is Stratix 10 and Arria 10 and Cyclone 10 GX!
Intel is not discontinue or stop supporting. But the bug fix will depend on how critical the issue, it there are alternative way of doing it, it will not fixed in any time soon.
