NAdel1
6 years agoApplication and factory image, Cyclon V, Quartus 18.1.1, when the data is corrupted, the factory runs again and again
I can write and read to the quad flash using Generic Flash Serial IP and it works, but When there is problem in the middle of the application image (not in the start where the RSU looking before the ...
YuanLi_S_Intel
6 years agoHi Naftali,
Setting ANF to 1 means that you are booting application image. If application image corrupted, it will try to boot into application image for a few times and eventually will go back to factory mode.
Hope it helps
Thank You,
