JET60200's avatar
JET60200
6 years ago
Any easy way to merge multiple FPGA projects into a single one in Quartus Pro (19.2)?
I have two A10 FPGA projects, both of them implement special complex functions, and are verified to work corretcly.
Now I need merge both systems into a single system, so I need merge the two systems together. Is there ant easy way to get this done ? I don't wantto divide the second project into pieces, and then ADD(+) these pieces into the 1st system one after another. AS I Said, it's complicated, and I worry to introduce mistakes.
Is there a easy and safe way that Quartus can merge the two projects , and What I only need is to inter-connect the 2 sub-systems in “SYSTEM CONTENTS” tab simply ?
Thanks for help
