AN881 reference design need to be upgraded for device 1SM21CH.
Hi Sir,
I am very sorry for the inconvenience caused.
When I discovered the tcl file, the MX board already pass to others. So, I don’t have chance to verify it by myself. And in timely manner, I give you the steps and try it at your side with the hope to get a positive result. I need some time to get the board back.
And today, I just received the latest design from the author, he claimed that this design is verified work at his side. I checked this design still using E2 which I believe he is using some prototype board that using E2 device. Thus, I change it to E1, regenerate the qsys and run the TCL. I am then compiling the design. So, I just pass the SOF to you. If you available, please help to give it a try with this SOF. Otherwise, I will queue to get the board and test it on my side.
From this latest design, I can see the BAR setting is turned on for BAR2 and BAR4 which I believe it’s more reliable.
I also attach the design QAR for your reference. This design is using 19.2. Anyway, you do not need to install 19.2 as for now. You can use 19.3 programmer to program the SOF and test it directly.
We have tested this with sof.
It still doesn’t work at our side.
Could the author provide the environment information like motherboard name, Linux version, and Quartus version? And try the the device exact the same with ours?
