AN881 reference design need to be upgraded for device 1SM21CH.
Hi, I am able to setup the design and I also facing the same problem as yours. I will try to contact the design author and clarify.
One thing to check with you is when i run the driver, I am unable to see HBM2=2 and DDR4=4 n preset 5. I only can see change BAR -1=None. For this I am using the unzip software folder under the reference design. Are you using other software driver?
at the same time, can give a check with command as below to see if the BAR2 and BAR4 si detect in the system.
Lspci -nn | grep 1172 to check the BDF.
Eg, if theBDF is 5:0.0 then run command as blow:
Lspci -s 05:00.0 -vvv
By the way, please contact the design author as soon as possible to see what's wrong.
We have to make our deadline, because there will be a demo of our design to customers in the end of December.
This FPGA board has been bought for almost 2 months.
However, no reference design works so far.
https://fpgacloud.intel.com/devstore/platform/?acds_version=any&family=stratix-10&board=104
We assumed that at least one of above reference designs could prove this board's function is normal.
But the simplest "on-chip memory reference design" cannot be installed. (I've asked another question about this issue on community)
And the other three reference designs cannot work.
If there is no way to prove the functionalities of this FPGA kit,
maybe we need to return it to Intel.
