AN881 reference design need to be upgraded for device 1SM21CH.
Sorry, previously I use 1SM21CHU1F53E1VGS1 and able to re-generate the IP and recompile.
However, when i change the device to 1SM21CHU1F53E1VG, I am unable to generate the HBM IP with errors as below, I will work with internal team on this errors.
Can you briefly explain how you upgrade the design and able to generate the IP without error?
At the same time, maybe you can use other non-hbm design and upgrade to 1SM21CHU1F53E1VG and retry. The goal now is want to get a non working design that able to let linux detect the device.
Error(20327): 2019.11.13.15:18:28 Error: g3x16_hbm2: hbmc_0 has port axi_0_1_araddr declared with width 28 which is declared with width 29 in file hbmc_0.ip
2019.11.13.15:18:28 Error: g3x16_hbm2: hbmc_0 has port axi_0_0_awaddr declared with width 28 which is declared with width 29 in file hbmc_0.ip
2019.11.13.15:18:28 Error: g3x16_hbm2: hbmc_0 has port axi_0_1_awaddr declared with width 28 which is declared with width 29 in file hbmc_0.ip
2019.11.13.15:18:28 Error: g3x16_hbm2: hbmc_0 has port axi_0_0_araddr declared with width 28 which is declared with width 29 in file hbmc_0.ip
2019.11.13.15:18:28 Error: The system cannot be generated when there are errors.
- CHung6 years ago
I also met these errors when I used Quartus v19.3.
You could try v19.1, it could upgrade HBM2 smoothly.
