CHung
6 years agoAN881 reference design need to be upgraded for device 1SM21CH.
Hi, The following reference design is based on 1SM21BH device. https://fpgacloud.intel.com/devstore/platform/19.1.0/Pro/an881-pcie-avmm-dma-gen3x16-ddr4-and-hbm2/ We use Stratix 10 MX 1SM21C...
BoonT_Intel
6 years agoThey are the same, I check the example design in edv kit package. All pin location is compatible.
This this moment, maybe you should signalap the PCIe signal and understand where the problem come from. Example of signal tap signals as below:
- CHung6 years ago
OK. I'll do it.
Thank you.
- CHung6 years ago
Hi
We have dumped PCIe signalTap waveforms (.jpg and .vcd), please download here:
http://gofile.me/4v7Zs/5QrPiwKwN
- pcie_reset_trigger
- pcie_reset_release
- avmm_bridge_512_0_rst_n_release
- pcie_idle
1, 2, 3 are the waveform around system reset.
4 is the waveform after reset.
Because we are not familiar with PCIe protocol and signals inside IP,
could you please help to analyze them?
It seems clocks and reset signals are OK. But Linux could not recognize it.
