Hi Wim,
In order to find the demo_2c35 you require an older version of the reference design such as an374-v2.4.0. This version however has only been tested with Quartus 7.2. It did not work for me using Quartus 8.0. Cheers, Mike - Altera_Forum
Thanx for the info, requested it from Altera and got it this weekend.
At this moment I'm busy trying to understand the LCD TV example delivered with the NEEK board. I'll try to use this for video input to the "Video over IP". I'll post again if I'm able to get the "Video over IP" running on the NEEK. Regards, Wim. - Altera_Forum
Hi all,
Sorry for being so direct but I'm really stuck with the v3.3.0 package and I want to test an older package.... does anybody have downloaded this version of the vider over ip (an374) package :an374-v2.4.0
if yes, is it possible to send me the package by mail ?? Thanks guys !
split the zip in to 2 files and send them by email but it was rejected by gmail because of a illegal attachment.
Send an email to Altera support they will make it available on a ftp server for you to download. This is the way I got it. - Altera_Forum
Hi xamrob,
The Altera support does not respond to my mails.... Can you try again to send me the package on my mail/on a FTP ??? Thanks !!! - Altera_Forum
Look in your gmail box
Hi xamrob,
Can you try again to send me the package on my mail:sochuangdz@gmail.com - Altera_Forum
Dear xamrob,
This is my company website:http://cdscdz.en.alibaba.com/ and www.sochuang.com (http://www.sochuang.com) ; Can you send an374-v2.4.0 or other version to me?my e-mail address: 110.yes@gmail.com and 100.yes@163.com . thanks so much! benter, - Altera_Forum
--- Quote Start --- split the zip in to 2 files and send them by email but it was rejected by gmail because of a illegal attachment. Send an email to Altera support they will make it available on a ftp server for you to download. This is the way I got it. --- Quote End --- Hello, Would you please send the same design example to my e_mail: marwafareed@yahoo.com Thanks & Regards - Altera_Forum
Maybe someone tried to use this reference design on DE2-115? The problem is SDRAM there, is it sufficient for video data streaming or it is too slow and at least DDR RAM is needed?
EDIT: Ok then, did anyone manage to run the VoIP reference design on NEEK board? :)
