10 years agoan 690 error upgrade IP
Hi, I am trying to use the example AN690. I want to use PCIe with DMA for Stratix V. I tried to run the example on quartus v14.1 but it gives me a warning to upgrade IP components. When I perfo...
10 years agoYou can try to use the same Quartus II version as the design example to avoid any incompatibility issue. From 13.1 to 14.0, there are significant changes in some of the IP cores from megawizard to IP editor. Not sure if this will cause the issue that you are seeing.
