AJama4
6 years agoAMP solution for Intel Boards for Inter-processor communication
What is the AMP solution for Intel boards like De1-SoC Board? Is there any application note guiding which approach a programmer should adopt? Xilinx uses the OpenAMP project as the default AMP soluti...
Deshi_Intel
6 years agoHi,
Thanks for the clarification.
May I know what's AMP ? Does it mean "Asymmetric Multiprocessing" which is what I google out.
Let me explain.
- Intel is offering certain design solution but Intel also leverage 3rd party vendor like Terasic to help provide certain IP or design solution to customer.
- Application note or reference design may comes from Intel or 3rd party design partner
Take DE1-SOC board for example.
- Terasic may developed certain application note or reference design solution to help promote their board but this is not within Intel control or support. That's why I recommend you to checkout with Terasic
If you refer to AMP solution from Cyclone V SOC, then I managed to found out below 2 links. Hopefully they are helpful to you
- https://fpgacloud.intel.com/devstore/platform/16.1/Standard/multi-core-amp-development-tools-for-altera-cyclone-v-soc/
- https://rocketboards.org/foswiki/Projects/DeviceWideAMP
If you still need more help or clarification on AMP solution support then I will route this forum thread to Intel FPGA embedded support agent so that they can better assist you.
Let me know.
dlim
