11 years agoAlternative to DE1 control panel?
As a lot of users here I have problems with the DE1 control panel. It exits with the error message "Please make sure Quartus is installed". The DE1 manual states that it has to be Quartus 12.0 or new...
11 years agoThe only examples I've seen of programming a parallel flash uses a NIOS 2 processor on the FPGA that talks to the flash programmer (not quartus programmer as I said above). On youtube there is a "my first nios ii" tutorial that does this in the 2nd half of part 2. It's for a DE2 board, so you might need to change the timing settings based on the flash chip on the DE1 if it is different than the DE2. It is an older tutorial based on sopc builder, not QSYS. Still you might be able to figure out how to set up a QSYS nios system on the DE1 using that tutorial as guidance.
I followed that tutorial a few years ago with sopc builder on my DE2 board and it worked.
