altera_remote_update: Set application image address (Cyclone V)
- 5 years ago
Thank you for your reply.
I am using the page select signal in order to provide that remote update core with my desired flash address. In order to determine which application image to load, I am using a flash sector to store boot information, which i read before loading the application.
Kind regards.
For your scenario, i believe you could select the application image to boot first by using the remote update IP. You may refer to the user guide below particular on the "page select" parameter.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_altremote.pdf (Page 21)
Thank You
Kind regards.
