17 years agoAltera PCI Express Development Kit: Linux DMA Driver
Hi, I am a newbie to FPGA design and implementation. While installing the PCI express board on LINUX machine, I don't see Demo application driver for DMA read and write for LINUX (Manual talk...
16 years agoArria is on PCIe bus.PCIe has his own interrupt controller,so there are no physical interrupts.They are virtual.In my case I received a IRQ#4538 line using Linux.
To start DMA read/write you have to write the number of descriptors to transfer, to the &read_header->w3 in the altpciechdma driver. Example:iowrite32(n,&read_header->w3). Look through the driver source code. Everything is commented. ug_pci_express.pdf has the description of the Altera MegaCore function. Read /Documents/DMA.txt in your Linux documentation to better understand the chaining DMA.
