17 years agoAltera PCI Express Development Kit: Linux DMA Driver
Hi, I am a newbie to FPGA design and implementation. While installing the PCI express board on LINUX machine, I don't see Demo application driver for DMA read and write for LINUX (Manual talk...
17 years ago --- Quote Start --- Alright: I downloaded the application note and tried out all 4 of the .sof files provided for Arria GX... x1 Legacy: no device in lspci x4 Legacy: device shows, driver hangs with EPLAST=44 on the 1st memory transfer. x1 ST: no device in lspci x4 ST: no device in lspci --- Quote End --- The only problem I had running the chainging_dma example created by the core was the following. If I used the Avalon Interface the generated exampled tied the rx_st_ready0 signal to 0 which causes windows to hang on boot. Maybe its the same reason here, but I guess you used a .sof file by altera?
