17 years agoAltera PCI Express Development Kit: Linux DMA Driver
Hi, I am a newbie to FPGA design and implementation. While installing the PCI express board on LINUX machine, I don't see Demo application driver for DMA read and write for LINUX (Manual talk...
17 years ago --- Quote Start --- Hi , Is there a limitation in size of DMA block for altera reference design ? I am not able to DMA more than 32KB buffer when buffer (to be DMA'ed) is filled with random data. Thanks in advance. Regards, Vineet --- Quote End --- I think so, the Compiler User Manual (9.0) says bar 1:0 32kB, 3:2 at least 256 byte andbar 5:4 32kB. See Table 7-4. Or did you used the provided .sof file instead? In this case bar 0 should be 16 MB.
