Armando1989
1 year agoAltera Max, reset at startup?
Hi there Im having issue with the startup status on cpld, seems it does not reset itself on bootup or i dont know how to... So, for instance, a code which alternate output enable signal between lat...
- 1 year agoHi,
according to project files, you are using MAX7000. It's a long time that I designed with the device family, if I remember right, it involves an internal POR.
Problem is that an asynchronous reset (either POR or dedicated external signal) may cause occasionally unexpected state of registers if clock is already running. Reset must be synchronized to clock to overcome the issue.
There are several reason why POR may not be sufficient, e.g. non-monotic supply rise.
An external supply supervision chip with delay can solve problems, reset synchronization to clock may be still required.
AqidAyman_Altera
1 year agoHi Armando,
May I know if there is any more support/help needed from you for this question?
Aqid
Armando1989
1 year agoHi
Think is ok by FvM answer, ill check and redesign based on it
Br
Br
