14 years agoAltera DE0 Nano USB Video streaming
Hello, I am currently involved in a project to develop a vision system that can stream images from a CMOS 5MP camera module to a PC and display the image using the NIOS2 processor of the DE0 Na...
14 years ago --- Quote Start --- are there any ready to use FTDI modules available on Digikey or Sparkfun? If so could you kindly post the link? --- Quote End --- I purchased these two modules: http://search.digikey.com/scripts/dksearch/dksus.dll?vendor=0&keywords=um245r http://search.digikey.com/scripts/dksearch/dksus.dll?vendor=0&keywords=ft2232h+mini+module --- Quote Start --- Are there any additional hardware that needs to be soldered on to a PCB to make the DE0 Nano <-> FTDI chip interface work --- Quote End --- No extra hardware needed. I plugged the UM245R module into the BEMICRO-PROTO board and tested the asynchronous FIFO interface. I haven't tested the FT2232H and its synchronous FIFO interface. --- Quote Start --- What protocol is suggested to be used to facilitate communication between the DE0Nano and FTDI chip, (for e.g. SPI or I2C or UART) to get a speed close to High speed? --- Quote End --- The UM245R FIFO mode uses an 8-bit data plus 4 control signals interface. I haven't looked at the requirements for the FT2232H synchronous FIFO interface. Cheers, Dave
