Altera Cyclone V SoC chip overheating
- 7 years agoHi Shiva, I recommend you to use deferential prob and to attach the prob first before powering the board without touching any pin by mistake. It seems a user error, The board was working fine until you manually probed some pins then the issue appeared. Please take care while touching any pin while running as some pins are so sensitive (mainly the feedback pin of power devices and some digital pins). Regards.
@Embedded_guy, Yes I have perfomance issues with the board.
When I boot with the default Xfce image that comes along with the board...The execution stops at HDMI Warning Step and then automatically resets. This keeps on happening again and again. If possible can you explain what would have gone wrong?.. I did not do anything. I just put the default image that came along with the SD Card.
Here is the Log of the execution
U-Boot SPL 2017.03-rc2 (Mar 30 2017 - 19:07:16)
/data/de10-nano/release-build-2017.03.31/build/tmp-angstrom-glibc/work/de10_nano -angstrom-linux-gnueabi/u-boot-socfpga/v2017.03+gitAUTOINC+d03450606b-r0/git/dri vers/ddr/altera/sequencer.c: Preparing to start memory calibration
/data/de10-nano/release-build-2017.03.31/build/tmp-angstrom-glibc/work/de10_nano -angstrom-linux-gnueabi/u-boot-socfpga/v2017.03+gitAUTOINC+d03450606b-r0/git/dri vers/ddr/altera/sequencer.c: CALIBRATION PASSED
/data/de10-nano/release-build-2017.03.31/build/tmp-angstrom-glibc/work/de10_nano -angstrom-linux-gnueabi/u-boot-socfpga/v2017.03+gitAUTOINC+d03450606b-r0/git/dri vers/ddr/altera/sequencer.c: Calibration complete
Trying to boot from MMC1
U-Boot 2017.03-rc2 (Mar 30 2017 - 19:07:16 -0700)
CPU: Altera SoCFPGA Platform
FPGA: Altera Cyclone V, SE/A6 or SX/C6 or ST/D6, version 0x0
BOOT: SD/MMC Internal Transceiver (3.0V)
Watchdog enabled
I2C: ready
DRAM: 1 GiB
MMC: dwmmc0@ff704000: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Model: Terasic DE10-Nano
Net:
Error: ethernet@ff702000 address not set.
No ethernet found.
Hit any key to stop autoboot: 0
reading de10-nano.rbf
3368700 bytes read in 257 ms (12.5 MiB/s)
Setting bus to 2
921738 bytes read in 85 ms (10.3 MiB/s)
reading de10_nano_hdmi_config.bin
72872 bytes read in 16 ms (4.3 MiB/s)
## Starting application at 0x0C100001 ...
HDMI WARNING: No HDMI display detected
HDMI WARNING: no valid timing found, setting 1024x768 default
/data/de10-nano/release-build-2017.03.31/build/tmp-angstrom-glibc/work/de10_nano-angstrom-linux-gnueabi/u-boot-socfpga/v2017.03+gitAUTOINC+d03450606b-r0/git/drivers/ddr/altera/sequencer.c: Preparing to start memory calibration
/data/de10-nano/release-build-2017.03.31/build/tmp-angstrom-glibc/work/de10_nano-angstrom-linux-gnueabi/u-boot-socfpga/v2017.03+gitAUTOINC+d03450606b-r0/git/drivers/ddr/altera/sequencer.c: CALIBRATION PASSED
/data/de10-nano/release-build-2017.03.31/build/tmp-angstrom-glibc/work/de10_nano-angstrom-linux-gnueabi/u-boot-socfpga/v2017.03+gitAUTOINC+d03450606b-r0/git/drivers/ddr/altera/sequencer.c: Calibration complete
Watchdog enabled
I2C: ready
DRAM: 1 GiB
In: serial
Out: serial
Err: serial
Net:
No ethernet found.
3368700 bytes read in 258 ms (12.5 MiB/s)
Setting bus to 2
