Altera 1588 FPGA solution
HI,
Alright, so you have get the TSE MAC working and now the issue seems to resides in MSGDMA side, right ?
Unfortunately I am not familiar with MSGDMA but I did found some reference design that you can take a look as reference. It's targeting different FPGA product but the reference design did use TSE and MSGDMA. So, you can check it out
https://rocketboards.org/foswiki/News/TripleSpeedEthernetWithMSGDMALinuxExampleDesignIsNowAvailable
dlim
- AKb6 years ago
Thank you for the link. I had seen that example. It is implemented in Cyclone V SOC and is using Linux. I am using Cyclone 10 Custom board and want to implement triple speed ethernet using msgdma in Nios.
I am now able to read the pumped input data in Buffer using msgdma. The problem is that how to find out the Packet has started and Packet has ended since i am feeding streamed data. I am struck in this problem.
If possible kindly guide
Av
