[Agilex]:Error Sending Bitstream..!!
- 2 years ago
Hi Raju,
Thanks, will close this and move the support to below to avoid any confuse.
Compilation Error in Quartus Prime 23.3 for Agilex PCIe Root Port Design Example - Intel CommunityRegards,
Wincent_Intel
p/s: If any answer from the community or Intel Support is helpful, please feel free to give the best answer or rate 9/10 survey.
Hi @Wincent_Altera ,
Thank you for your response.
I have attempted to resolve the issue by re-downloading the SD Card Image, but unfortunately, I continue to face the same problem.
Is it possible for you to provide the example design files along with detailed building steps for Linux and U-Boot?
Thanks & Regards
Raju Satrasala
- Wincent_Altera2 years ago
Hi Raju,
Seen like this issue is more related to Linux booting using U-boot.
For your information, I am support specialist for PCIe IP and design implementation.
Could you please file another forum with title " Linux boot-up failed with Agilex 7 F-Series SOC Development Kit "
for the categories, please ensure you select something related to "embedded" instead of "PCIe".
The correct support specialist should receive your case and continue to support you.
Do you have any queries about PCIe ? If not I would like to have your permission to close this case.Regards,
Wincent_Intel
