[Agilex]:Error Sending Bitstream..!!
- 2 years ago
Hi Raju,
Thanks, will close this and move the support to below to avoid any confuse.
Compilation Error in Quartus Prime 23.3 for Agilex PCIe Root Port Design Example - Intel CommunityRegards,
Wincent_Intel
p/s: If any answer from the community or Intel Support is helpful, please feel free to give the best answer or rate 9/10 survey.
Hi @Wincent_Altera ,
Please find the below table for reference
| Switch Configuration | ||
| Rocket Board Agilex SOC GSRD | Rocket Board PCI RP | Agilex EVM Working |
| SW1: ON-ON-ON-ON | SW1: ON-ON-ON-ON | SW1: ON-ON-ON-ON |
| SW2: All OFF | SW2: All ON | SW2: All OFF |
| SW3: OFF-OFF-ON-ON-ON-ON | SW3: All OFF | SW3: OFF-OFF-ON-ON-ON-ON-ON-ON |
| SW4: OFF-OFF-OFF-ON | SW4: ON-OFF-ON-OFF | SW4: OFF-OFF-OFF-OFF |
https://www.rocketboards.org/foswiki/Documentation/agilexSoCGSRD
Rocket Board PCI RP
Agilex PCIe Root Port | Documentation | RocketBoards.org
We attempted to utilize the Rocket Board PCI RP Switch Configuration, but encountered issues with detecting the JTAG Chain. However, when we employed the Agilex EVM Working Switch Configuration, we were able to successfully detect the JTAG Chain.
Thanks & Regards
Satrasala Raju
- Wincent_Altera2 years ago
Hi Raju,
Glad that you are able to solve this issue and proceed further.
Also, Thanks for sharing with me how you solve this issue. Appreciate that.
Hence, I will set close this forum loop, if you have any further question, feel free to raise another case anytime.If your support experience falls below a 9 out of 10, I kindly request the opportunity to rectify it before concluding our interaction. If the issue cannot be resolved, please inform me of the cause so that I can learn from it and strive to enhance the quality of future service experiences.
Wincent_Intel
- raju14212 years ago
The issue remains unresolved, despite our modifications to the switch configuration, we have successfully detected the JTAG chain.
Provide me the working files which is present in the
Thanks & Regards
Satrasala Raju
Hi Raju,
Sorry I misunderstand your meaning, and I do not realise you have jtag detection problem at the beginning.
The design at rocketboard shall be correct, could you please re-download and try it again ?
I suspect there might be some corruption when you trying to download it.
Regards,Wincent_Intel
