[Agilex]:Error Sending Bitstream..!!
- 2 years ago
Hi Raju,
Thanks, will close this and move the support to below to avoid any confuse.
Compilation Error in Quartus Prime 23.3 for Agilex PCIe Root Port Design Example - Intel CommunityRegards,
Wincent_Intel
p/s: If any answer from the community or Intel Support is helpful, please feel free to give the best answer or rate 9/10 survey.
Hi @Wincent_Altera ,
Thank you for your response.
We are utilizing the default wic image from the Intel Agilex® 7 FPGA F-Series SoC binaries archive for SD-Card booting.
However, we are still encountering the error mentioned earlier.
Thanks & Regards
Raju Satrasala
- Wincent_Altera2 years ago
Hi Raju,
I saw one Intel Article mentioned the same problem as you facing
https://www.intel.com/content/www/us/en/support/programmable/articles/000074735.html
Perhaps you can try the resolution mentioned there and see if this solve your problem or not.
Regards,Wincent_Intel
